Depending on set flags format of response can differ.
This chapter describes flags that can be applied to resources and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be united into one JSON.
All flags are only used in DEC format.
Resource flags:
| Value HEX | Value DEC | Description |
| 0x00000001 | 1 | base flag |
| 0x00000002 | 2 | custom properties |
| 0x00000004 | 4 | billing properties |
| 0x00000008 | 8 | custom fields |
| 0x00000020 | 32 | messages |
| 0x00000040 | 64 | GUID |
| 0x00000080 | 128 | administrative fields |
| 0x00000100 | 256 | drivers |
| 0x00000200 | 512 | jobs |
| 0x00000400 | 1024 | notifications |
| 0x00000800 | 2048 | POIs |
| 0x00001000 | 4096 | geofences |
| 0x00002000 | 8192 | report templates |
| 0x00004000 | 16384 | list of auto attachable units for drivers |
| 0x00008000 | 32768 | driver groups |
| 0x00010000 | 65536 | trailers |
| 0x00020000 | 131072 | trailer groups |
| 0x00040000 | 262144 | list of auto attachable units for trailers |
| 0x00080000 | 524288 | orders |
| 0x00100000 | 1048576 | geofences groups |
| 0x00200000 | 2097152 | tags (passengers) |
| 0x00400000 | 4194304 | automatic binding list of units (for tags) |
| 0x00800000 | 8388608 | tags groups(passengers) |
| 0x3FFFFFFFFFFFFFFF | 4611686018427387903 | set all possible flags to resource |
Flag - 0x00000001
{ "nm":<text>, /* name */ "cls":<uint>, /* superclass ID: "avl_resource" */ "id":<uint>, /* resource ID */ "mu":<uint>, /* measure units: 0 - si, 1 - us, 2 - imperial, 3 - metric with gallons */ "uacl":<uint> /* current user access level for resource */ }
Flag - 0x00000002
You can store any resource data you need in custom properties.
{ "prp":{ /* custom properties */ "emails":"[<text>]", /* list of e-mails for jobs */ "nf_rep_emails":"[<text>]", /* list of e-mail for notifications */ "phones":"[<text>]", /* list of phone numbers for job "Send fuel information by e-mail or SMS" */ ... }, "ftp": { /* FTP settings */ "hs":<text>, /* host */ "lg":<text>, /* login */ "pt":<text>, /* directory path */ "ch": <uint>, /* FTP settings validity: 1-yes, 0-no */ "tp": <uint>, /* use wialon hosting FTP: 1 - yes, 0 - no */ "fl": <uint> /* is wialon hosting FTP available: 1 - yes, 0 - no */ } }
Flag - 0x00000004
{ "crt":<uint>, /* creator ID */ "bact":<uint>, /* account ID */ "bpact":<uint> /* parrent account ID */ }
Flag - 0x00000008
{ "flds":{ /* custom fields */ "<uint>":{ /* sequence number */ "id":<uint>, /* ID */ "n":<text>, /* name */ "v":<text> /* value */ }, ... }, "fldsmax":<long>, /* maximal count of custom fields (-1 - unlimited) */ }
Flag - 0x00000020
After setting this flag you can receive resource messages.
Flag - 0x00000040
{ "gd":<text> /* resource GUID */ }
Flag - 0x00000080
{ "aflds":{ /* administrative fields */ "<uint>":{ /* sequence number */ "id":<uint>, /* ID */ "n":<text>, /* name */ "v":<text> /* value */ }, ... }, "afldsmax":<long>, /* maximal count of administrative fields (-1 - unlimited) */ }
Flag - 0x00000100
{ "drvrs":{ <text>:{ /* sequence number of driver */ "id":<long>, /* ID */ "n":<text>, /* name */ "c":<text>, /* code */ "pwd":<text>, /* password for mobile authorization */ "ej":<text>, /* extentended JSON */ "jp": { /* custom fields */ <text>:<text>, /* name: value */ ... }, "ds":<text>, /* description */ "p":<text>, /* phone number */ "r":<double>, /* image aspect ratio */ "ck":<ushort> /* check sum (CRC16) */ "bu":<long>, /* binded unit */ "pu":<long>, /* previous binded unit */ "bt":<uint>, /* time of last binging/unbinding */ "pos":{ /* last position, null - if driver is bound to unit */ "y":<double>, /* latitude */ "x":<double> /* longitude */ }, infr: { /*parameters for analysis infringements of work and rest of drivers AETR */ "a": <uint>, /* current activity type (0 — rest, 1 — availability, 2 — work, 3 — driving) */ "t": <uint>, /* the start time of this activity in Unix time format */ "ud": <uint>, /* duration of uninterrupted driving before the current activity */ "ur": <uint>, /* duration of uninterrupted rest before the current activity */ "uil": <uint>, /* allowed duration of uninterrupted driving (270 min) */ "uim": <uint>, /* duration of uninterrupted driving to which the infringement is considered minor (300 min) */ "uis": <uint>, /* duration of uninterrupted driving to which the infringement is considered serious (360 min); above - very serious */ "uir": <uint>, /* duration of required rest (45 minutes for each 4.5 hours) */ "ddt": <uint>, /* daily driving time before the current activity (total driving) */ "dbt": <uint>, /* start time of daytime activity in Unix time format */ "ddc": <uint>, /* allowed number of prolonged daily driving in this week (decrements from 2 to 0; connected to ddil, ddim, ddis) */ "ddil": <uint>, /* allowed duration of daily driving (if ddc:0 value is 600, else 540) */ "ddim": <uint>, /* allowed duration of daily driving up to which the infringement is considered minor (if ddc:0 value is 660, else 600) */ "ddis": <uint>, /* allowed duration of daily driving up to which the infringement is considered serious (if ddc:0 value is 720, else 660); above - very serious */ "wdt": <uint>, /* duration of weekly driving before the current activity */ "wdil": <uint>, /* allowed duration of weekly driving (3360 min) */ "wdim": <uint>, /* allowed duration of weekly driving up to which the infringement is considered minor (3600 min) */ "wdis": <uint>, /* allowed duration of weekly driving up to which infringement is considered serious (4200 min); above - very serious */ "twdt": <uint>, /* duration for two weeks of driving before the current activity */ "twdil": <uint>,/* allowed duration for two weeks of driving (5400 min) */ "twdim": <uint>,/* allowed duration for two weeks of driving up to which the infringement is considered minor (6000 min) */ "twdis": <uint>,/* allowed duration for two weeks of driving up to which the infringement is considered serious (6750 min); above - very serious */ "drt": <uint>, /* duration of the previous daily rest */ "drd": <uint>, /* duration of the required daily rest (660 min by default, 540 min for reduced daily rest) */ "dril": <uint>, /* time in Unix time format up to which daily rest should begin */ "drim": <uint>, /* time in Unix time format up to which violation of the rest period is considered minor (60 min more) */ "dris": <uint>, /* time in Unix time format up to which violation of the rest period is considered serious (120 min more); above - very serious */ "wrt": <uint>, /* duration of the previous weekly rest */ "wrd": <uint>, /* duration of the required weekly rest (2700 min by default, 1440 min for reduced weekly rest) */ "wril": <uint>, /* time in Unix time format up to which weekly rest should begin */ "wrim": <uint>, /* time in Unix time format up to which violation of the rest period is considered minor (120 min more) */ "wris": <uint> /* time in Unix time format up to which violation of the rest period is considered serious (240 min more); above - very serious */ } }, ... }, "drvrsmax":<long> /* maximal count of drivers (-1 - unlimited) */ }
Flag - 0x00000200
{ "ujb":{ <text>:{ /* sequence number of job */ "id":<uint>, /* ID */ "n":<text>, /* name */ "d":<text>, /* description */ "m":<uint>, /* maximal allowed executions count */ "st":{ /* state */ "e":<uint>, /* active/inactive */ "c":<uint>, /* executions count */ "l":<uint> /* last execution time */ }, "act":<text> /* action type */ }, ... }, "ujbmax":<long>, /* maximal count of jobs (-1 - unlimited) */ }
Types of actions are described in the chapter Jobs: detailed information.
Flag - 0x00000400
{ "unf":{ <text>:{ /* sequence number of notification */ "id":<long>, /* ID */ "n":<text>, /* name */ "ta":<uint>, /* activation time */ "td":<uint>, /* deactivation time */ "ma":<uint>, /* maximal alarms count (0 - unlimited) */ "fl":<uint>, /* notification types */ "ac":<uint>, /* alarms count */ "un":[<long>], /* array of units IDs */ "act":[<text>], /* actions list */ "trg":<text>, /* type of control */ "crc":<long> /* check sum of binary view of notification */ }, ... }, "unfmax":<long>, /* maximal count of notifications (-1 - unlimited) */ }
Action types, control types and notification flags are described in the chapter Notifications: detailed information.
Flag - 0x00000800
> { "poi":{ <text>:{ /* sequence number of POI */ "id":<long>, /* ID */ "n":<text>, /* name */ "y":<double>, /* latitude */ "x":<double>, /* longitude */ "t":<double>, /* image aspect ratio */ "i":<short>, /* check sum of image (CRC16) */ "e":<ushort> /* check sum of POI (CRC16) */ }, ... }, "poimax":<long> /* maximal count of POIs (-1 - unlimited) */ }
Flag - 0x00001000
{ "zl":{ <text>:{ /* sequence number of geofence */ "n":<text>, /* name */ "d":<text>, /* description */ "id":<long>, /* ID */ "f":<uint>, /* flags */ "t":<int>, /* type: 1 - line, 2 - polygon, 3 - circle */ "e":<ushort> /* check sum (CRC16) */ "b":{ /* configuration for rendering geofences */ "min_x":<double>, /* minimal longitude */ "min_y":<double>, /* minimal latitude */ "max_x":<double>, /* maximal longitude */ "max_y":<double>, /* maximal latitude */ "cen_x":<double>, /* longitude of center */ "cen_y":<double> /* latitude of center */ } }, ... }, "zlmax":<long> /* maximal count of geofences (-1 - unlimited) */ }
Geofence flags are described in the chapter Geofences: detailed information.
Flag - 0x00002000
{ "rep":{ <text>:{ /* sequence number of template */ "id":<long>, /* ID */ "n":<text>, /* name */ "ct":<text>, /* template type */ "c":<ushort> /* check sum (CRC16) */ }, ... }, "repmax":<long> /* maximal count of templates (-1 - unlimited) */ }
Types of templates are described in the chapter Get templates data.
Flag - 0x00004000
{ "drvrun":[<long>] /* array IDs of auto attachable units */ }
Flag - 0x00008000
{ "drvrsgr":{ /* driver groups */ <text>:{ /* sequence number of group */ "id":<long>, /* group ID */ "n":<text>, /* name */ "d":<text>, /* description */ "drs":[<uint>] /* array of drivers IDs */ }, ... }, "drvrsgrmax":<long> /* maximal count of driver groups (-1 - unlimited) */ }
Flag - 0x00010000
{ "trlrs":{ /* trailers */ <text>:{ /* sequence number of trailer */ "id":<long>, /* trailer ID */ "n":<text>, /* name */ "c":<text>, /* code */ "ej":<text>, /* extentended JSON */ "jp":{ /* custom fields */ <text>:<text>, /* name: value */ ... }, "ds":<text>, /* description */ "p":<text>, /* phone number */ "r":<double>, /* image aspect ratio */ "ck":<short>, /* check sum of image */ "bu":<long>, /* binded unit */ "pu":<long>, /* previous binded unit */ "bt":<uint>, /* time of last binding/unbinding */ "pos":{ /* position */ "y":<double>, /* latitude */ "x":<double> /* longitude */ } } }, "trlrsmax":<long> /* maximal count of trailers (-1 - unlimited) */ }
Flag - 0x00020000
{ "trlrsgr":{ /* trailer groups */ <text>:{ /* sequence number of group */ "id":<long>, /* group ID */ "n":<text>, /* name */ "d":<text>, /* description */ "drs":[<uint>] /* array of trailers IDs */ } }, "trlrsgrmax":<long> /* maximal count of trailer groups (-1 - unlimited) */ }
Flag - 0x00040000
{ "trlrun":[<long>] /* array IDs of auto attachable units */ }
Флаг - 0x00080000
{ "orders":{ "<uint>": { /* order number, the same as in "id" param */ "id":<uint>, /* order id within resource */ "n":<text>, /* order name */ "p":{ /* user-defined object content */ ... }, "f":<bool>, /* order flags: 1 - order would be marked as completed if there were at least one message within order area with zero speed in it */ "tf":<uint>, /* lower bound of order completion time */ "tt":<uint>, /* upper bound of order completion time */ "uid":<uint>, /* unique id (is used as unique key in order history) */ "r":<uint>, /* order point radius */ "y":<double>, /* order point lattitude */ "x":<double>, /* order point longitude */ "u":<long>, /* unit id */ "s":<uint>, /* order status: 0 - inactive (no unit assigned), 1 - active (unit assigned), 2 - completed in time, 3 - completed overdue, 4 - cancelled (not used) */ "st":<uint> /* last status modification time */ }, ... } }
Flag - 0x00100000
{ "zg":{ /* geofences groups */ <text>:{ /* sequence number of group */ "id":<long>, /* group ID */ "n":<text>, /* name */ "d":<text>, /* description */ "zns":[<uint>] /* array of geofences IDs */ }, ... }, "zgmax":<long> /* maximal count of geofences groups (-1 - unlimited) */ }
Flag - 0x00200000
"item": { "tags": { <uint>: { /* tag id*/ "id": <uint>, /* tag id*/ "n": <text>, /* tag name*/ "c": <text>, /* tag code */ "jp": {<text>:<text> }, /* custom fields, key:value */ "r": <double>, /* image aspect ratio */ "ck":<ushort> /* check sum (CRC16) */ "bu": <long>, /* binded unit */ "pu": <long>, /* previous binded unit */ "bt": <uint>, /* last binding/unbinding time */ "tz": <int>, /* time zone */ "art": <int>, /* automatic time unbinding */ "pos": { /* position */ "y": <double>, /* latitude */ "x": <double> /* longitude */ } }, ... }, tagsmax: -1 /* maximum number of tags */ },
Flag - 0x00400000
{ "tagrun":[<long>] /* array of units ID's for automatic binding */ }
Flag - 0x00800000
{ "tagsgr": { <long>: { /* group ID */ "id": <long>, /* group ID */ "n": <text>, /* group name */ "d": <text>, /* description */ "tgs": [<uint>] /* tags ID's array */ }, ... } "tagsgrmax": -1 /* maximum number of groups */ }
